 - Select SPBM.
 - Select the Multicast FIB tab.
Multicast FIB Field Descriptions
Use the data in the following table to use the Multicast FIB tab.
 Name  |
 Description  |
 SysId  |
 System ID of the node where the multicast FIB entry originated.  |
 Vlan  |
 VLAN of the multicast FIB entry.  |
 McastDestMacAddr  |
 Multicast destination MAC Address of the multicast FIB entry  |
 Isid  |
 I-SID of the multicast FIB entry.  |
                                 Isid Name  |
                                 Name assigned to the I-SID.  |
 HostName  |
 Host name of the node where the multicast FIB entry originated.  |
 OutgoingInterfaces  |
 Specifies the switched UNI port outgoing interface of multicast FIB entry.  |
 IncomingInterface  |
 Specifies the incoming interface (port or MLT) of the multicast FIB entry.  |
